[gdal-dev] OSM to KML Error
Josua S
josh-talk at hotmail.com
Wed Jul 3 04:20:10 PDT 2013
Hello
I exported an OSM file from openstreetmap.org and tried to convert it to KML with GDAL/OGR 1.10.0. However the conversion does not succeed and I get a lot of these errors: "ERROR 6: Interleaved feature adding to different layers is not supported". Is this a known problem and is there a solution to prevent this error? Thank you very much.
Josua
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130703/33b2c75e/attachment.html>
