[gdal-dev] hillshading to vector
Etienne Tourigny etourigny.dev at gmail.com
Thu Jul 4 12:21:19 PDT 2013
On Thu, Jul 4, 2013 at 3:58 AM, Carlo A. Bertelli (Charta s.r.l.) <
bertelli at charta.acme.com> wrote:
> Thanks a lot, Roger, it worked like a charm, just fiddling a little with
> parameters and than run it in python.
> It's really magic, I struggled with this question for two days before
> writing to the list.
> I think that instead of making another script you could add it as an
> option to gdal_contour.py and use it alternatively with -l (default) or -p
> (output to polygons).
not so sure about that, because the script requires matplotlib (although
the option could be disabled if matplotlib cannot be imported).
> By the way, another enhancement for gdal_contour could be adding an
> options to cut the output with a line or polygon layer (say the shoreline
> or other boundary).
> c
> c
>> On Wed, Jul 3, 2013 at 8:04 PM, Roger Veciana i Rovira <
>> rveciana at gmail.com> wrote:
>>> Hi, I was just working on that.
>>> I think that you need a script like gdal_contour, but creatig polygons
>>> instead of lines. The algorithm used is Marching Squares.
>>> You can see the code, without explanation, here:
>>> https://github.com/rveciana/geoexamples/tree/master/python/raster_isobands
>>> In some weeks I'll add some more info in a README file and transform the
>>> file into a working script, not just a function. But you can use it just
>>> changing the file name and the intervals.
>>> Roger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130704/0122ccd1/attachment.html>
