[gdal-dev] ogr2ogr fail: crtExitProcess
Even Rouault
even.rouault at mines-paris.org
Thu Jul 4 12:51:45 PDT 2013
Le jeudi 04 juillet 2013 20:48:37, Hilda Villegas a écrit :
> Hello,
> I'm using the ogr2ogr.exe to convert ENC files to shapefiles, the program
> extract the object from the ENC and creates the shapefile successfully,
> but it fails before finish.
> These are the parameters:
> ogr2ogr.exe -skipfailures
> C:\temp\ogr2ogr_test\Shapefiles\US5CA71M\aRESARE.shp -nlt polygon
> C:\temp\ogr2ogr_test\Enc\US5CA71M\US5CA71M.000 RESARE
> The program stopped at the crt0dat.c in the following section when I run it
> in debug mode: void __cdecl __crtExitProcess (
> int status
> __crtCorExitProcess(status);
> * Either mscoree.dll isn't loaded,
> * or CorExitProcess isn't exported from mscoree.dll,
> * or CorExitProcess returned (should never happen).
> * Just call ExitProcess.
> ExitProcess(status); <-----------
> This is the error message:
> "First-chance exception at 0x7761f9d2 in ogr2ogr.exe: 0xC0000008: An
> invalid handle was specified"
> Any thought about why this happened is appreciated.
It might be a bug in the ENC driver. Did you try with GDAL 1.10 ? If not, I'd
encourage you to do so. If it is GDAL 1.10, then could you provide your file so
that it can be investigated ?
> Best regards,
> Hilda Villegas
Geospatial professional services
http://even.rouault.free.fr/services.html
