[gdal-dev] Can't read NITF image
Nikos Alexandris nik at nikosalexandris.net
Sun Jul 7 12:41:14 PDT 2013
Hi!
I am trying to access an  .ntf  image.
gdalinfo /Some_Path/03APR13WV010500013APR03073140-
P1BS-500060446050_03_P002.ntf -noct -nomd -nogcp -sd 1
ERROR 4: `/vsisubfile/3884_478612158,/Some_Path/03APR13WV010500013APR03073140-
P1BS-500060446050_03_P002.ntf' not recognised as a supported file format.
ERROR 1: Unable to open JPEG2000 image within NITF file.
No JPEG2000 capable driver (JP2KAK, JP2ECW, JP2MRSID, JP2OPENJPEG, etc...) is
available.
You can define the NITF_OPEN_UNDERLYING_DS configuration option to NO, in order
to just get the metadata.
gdalinfo failed - unable to open '/Some_Path/03APR13WV010500013APR03073140-
P1BS-500060446050_03_P002.ntf'.
Indeed,
gdalinfo --formats | grep JPEG
  JPEG (rwv): JPEG JFIF
there is no JPEG2000 support (working in Funtoo, gdal installed via portage, I
think this: <http://gpo.zugaina.org/AJAX/Ebuild/2502482/View>)
Setting
export NITF_OPEN_UNDERLYING_DS=NO
let's me read the metadata.
Is this a *generic* problem or else, if I compile  --with-jasper  support will
allow for reading this image?  And, subsequently, import via r.in.gdal in
GRASS-GIS?
Thank you, Nikos
