[gdal-dev] tiles with different size, and irregular blocking
Even Rouault even.rouault at mines-paris.org
Tue Jul 9 01:23:16 PDT 2013
Selon Ahmet Temiz <ahmettemiz88 at gmail.com>:
> hello
> Is there any way to fix this problem:
> " tiles with different size, and irregular blocking"
Please give more context when you ask a question : at least the GDAL version
used, and the action you did when you got this message...
I had a hard time to figure out where this message come from. It seems that you
are using the PostgisRaster driver in GDAL 1.9 (or perhaps older), and that your
PostgisRaster table has tiles with different size and irregular blocking (the
error message is quite clear on that ;-)). This limitation is removed in GDAL
1.10, so upgrade !
Regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
