[gdal-dev] Feature (geometry and attributes) to GeoJSON
Even Rouault
even.rouault at mines-paris.org
Tue Jul 9 12:16:57 PDT 2013
Le mardi 09 juillet 2013 21:07:45, Baker, Anthony W a écrit :
> Seems that when I include the code from say OGR_G_ExportToJSon in my own
> code, I end up with lots of unresolved link errors. I guess that the
> GDAL_i.lib does not expose the functions that I need to use
> OGRGeoJSONWriteFeature. Maybe I am just missing something simple???
Yes this is an internal symbol of GDAL. If you really want it to be exported,
you can add CPL_DLL in its prototype, but this is at your own risks (= the
function might have disappeared or be renamed in any future version).
> Anthony
> -----Original Message-----
> From: Mateusz Loskot [mailto:mateusz at loskot.net]
> Sent: Tuesday, July 09, 2013 2:17 PM
> To: Baker, Anthony W
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Feature (geometry and attributes) to GeoJSON
> On 9 July 2013 18:58, Baker, Anthony W <Anthony.W.Baker at boeing.com> wrote:
> > Thank you for your response!
> > Is it possible to use the json_object directly with something like
> > json_object *json = OGRGeoJSONWriteFeature(poFeature);
> > Then just convert that to string?
> I'm sure it is. You've got the source, you can include whatever GDAL
> headers you like and use whatever is exposed from the binary.
> > I seem to get an error in json_object.h when I try this method with
> > "boolean redefinition".
> You may need to apply some fixes for your compiler.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
Geospatial professional services
http://even.rouault.free.fr/services.html
