[gdal-dev] GeoTIFF and LZWDecode (LZWEncode?) errors
Casper Børgesen (CABO) CABO at NIRAS.DK
Thu Jul 11 06:23:26 PDT 2013
Hi
When batch processing GeoTIFF files, I tend to get this problem a bit too often:
Warning 1: LZWDecode:LZWDecode: Strip 11 not terminated with EOI code
ERROR 1: LZWDecode:Not enough data at scanline 11 (short 30 bytes)
ERROR 1: TIFFReadEncodedStrip() failed.
band 1: IReadBlock failed at X offset 0, Y offset 11
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 11
The strip, scanline and offsets vary. It normally happens when I process from clients (computers) with the files located on servers (on local network), and I can reprocess a file again without getting the error, or possible an error with a different strip, scanline or offset. This special case is caused by gdaldem.exe and the error is reported by gdal_translate.exe using GDAL 1.9, but I have experienced this error using GDAL 1.9.2 and I think I saw it using GDAL 1.10 also.
I have two issues here:
1.       Why the problem is happening to begin with?
2.       Why does the Warning and/or Error not trigger ERRORLEVEL 1?
The first bullet I think can be very difficult to debug, so I seek experiences here. The second bullet is really frustrating, because I have to look through all my clients looking for output similar to the message above - and then reprocess all crashed files again.
One solution I have seen somewhere is to not compressing the files, but this results in quite an increase in disk space usage - way too high for me.
Kind regards, Casper
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130711/50a7061c/attachment-0001.html>
