[gdal-dev] GeoTIFF and LZWDecode (LZWEncode?) errors
Casper Børgesen (CABO)
CABO at NIRAS.DK
Thu Jul 11 06:56:56 PDT 2013
Hi Even.
I cannot reproduce the error, it just occurs when I'm batch processing and not necessarily at the same place/file. That's why I asked for experience.
However, when I get the error again, I can provide the corrupted file and then its possible to see that ex. Gdal_translate doesn't set ERRORLEVEL 1 or similar even though the process cannot continue.
Kind regards, Casper
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: 11. juli 2013 15:40
To: Casper Børgesen (CABO)
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GeoTIFF and LZWDecode (LZWEncode?) errors
Casper,
I'm not sure to have understood if you have this problem while reading or generating compressed files. Could you provide a way (that is to say provide both the input data and the command line used) of reproducing this ?
Best regards,
Even
> Hi
> When batch processing GeoTIFF files, I tend to get this problem a bit
> too
> often:
> Warning 1: LZWDecode:LZWDecode: Strip 11 not terminated with EOI code
> ERROR 1: LZWDecode:Not enough data at scanline 11 (short 30 bytes)
> ERROR 1: TIFFReadEncodedStrip() failed.
> band 1: IReadBlock failed at X offset 0, Y offset 11 ERROR 1:
> GetBlockRef failed at X block offset 0, Y block offset 11
> The strip, scanline and offsets vary. It normally happens when I
> process from clients (computers) with the files located on servers (on
> local network), and I can reprocess a file again without getting the
> error, or possible an error with a different strip, scanline or
> offset. This special case is caused by gdaldem.exe and the error is
> reported by gdal_translate.exe using GDAL 1.9, but I have experienced
> this error using GDAL 1.9.2 and I think I saw it using GDAL 1.10 also.
> I have two issues here:
> 1. Why the problem is happening to begin with?
> 2. Why does the Warning and/or Error not trigger ERRORLEVEL 1?
> The first bullet I think can be very difficult to debug, so I seek
> experiences here. The second bullet is really frustrating, because I
> have to look through all my clients looking for output similar to the
> message above - and then reprocess all crashed files again.
> One solution I have seen somewhere is to not compressing the files,
> but this results in quite an increase in disk space usage - way too high for me.
