[gdal-dev] installing GDAL with a custom installation of zlib
fred p
mapoubelle22 at gmail.com
Tue Jul 16 09:55:40 PDT 2013
Hello,
On a Linux platform, I have two versions of zlib :
- the older version is installed with the system in /usr/lib64
- the newer version is installed in a non standard directory
I launch the configure tool with the appropriate --with-zlib=/path/to/the/
newer/version/of/zlib
When compiling, this directory is actually used. But when I execute the
'make install' command, the binary tools I get depend on the older zlib
instead of the newer.
Can someone provide me some help ? Do I miss something ?
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130716/0289cf8c/attachment.html>
