[gdal-dev] using gdalwarp with a new projection in proj.4
Michael Speth
spethm at landcareresearch.co.nz
Tue Jul 16 18:48:19 PDT 2013
Greetings,
I am unable to use the HEALpix and rHEALPix projections which have been added about a year ago to proj.4 in gdalwarp. Is there a configuration file for gdal that needs to be updated for this projection?
Here is the command in question that fails:
gdalwarp -s_srs EPSG:26711 -t_srs '+proj=rhealpix -f '%.2f' -I +lon_0=0 +a=1 +ellps=WGS84 +npole=0 +spole=0 -E' ~/data/utm_orig.tif rhealpix.tif
The error message
“Translating source or target SRS failed:”
Thanks
Michael Speth
Research Systems Developer
Landcare Research
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130717/9f4ceeaa/attachment.html>
