[gdal-dev] using gdalwarp with a new projection in proj.4
Even Rouault
even.rouault at mines-paris.org
Thu Jul 18 14:44:28 PDT 2013
Le jeudi 18 juillet 2013 23:05:45, Markus Müller a écrit :
> Hi Frank,
> thanks for the reply. I did as you suggested and gdalsrsinfo acts
> accordingly.
> gdalsrsinfo '+proj=rhealpix -I +lon_0=0 +a=1 +ellps=WGS84 +npole=0 +spole=0
> +wktext'
> PROJ.4 : '+proj=rhealpix -I +lon_0=0 +a=1 +ellps=WGS84 +npole=0 +spole=0
> +wktext'
> OGC WKT :
> PROJCS["unnamed",
> GEOGCS["WGS 84",
> DATUM["unknown",
> SPHEROID["WGS84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["custom_proj4"],
> EXTENSION["PROJ4","+proj=rhealpix -I +lon_0=0 +a=1 +ellps=WGS84
> +npole=0 +spole=0 +wktext"]]
> I then tried the same with gdalwarp (on one of the examples file that comes
> with GDAL)
> gdalwarp -s_srs EPSG:26711 -t_srs '+proj=rhealpix -I +lon_0=0 +a=1
> +ellps=WGS84 +npole=0 +spole=0 +wktext' ~/data/utm_orig.tif rhealpix.tif
> Processing input file /home/markus.mueller/data/utm_orig.tif.
> ERROR 6: Failed to initialize PROJ.4 with `+proj=rhealpix -I +lon_0=0 +a=1
> +ellps=WGS84 +npole=0 +spole=0 +wktext'.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> It produces an output file though. Should I be concerned about the created
> error or can I ignore it?
Markus,
Yes, you shouldn't ignore this error. Ideally gdalwarp shouldn't complete when
such an error occurs. I'll look at that.
First, you should also remove the '-I' parameter. It is a argument of the proj
command line utility, not a parameter of a PROJ.4 projection string.
Secondly, looking at PROJ history (
http://trac.osgeo.org/proj/log/trunk/proj/src/PJ_healpix.c and
http://trac.osgeo.org/proj/log/tags/4.8.0?rev=2377 ), I see that this
projection was only introduced in PROJ 4.8.0, so check your PROJ.4 version. I
also see that a few fixes have been pushed after the 4.8.0 release, so if you
run into bugs, you might need to compile the trunk version of the svn
repository.
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
