[gdal-dev] using gdalwarp with a new projection in proj.4
Michael Speth
spethm at landcareresearch.co.nz
Thu Jul 18 23:17:40 PDT 2013
Even wrote:
I see that this projection was only introduced in PROJ 4.8.0, so check your PROJ.4 version.
Markus is using Rev 2375 of the proj.4 upstream SVN with the scaling patch for HEALPix/rHEALPix applied from this<http://trac.osgeo.org/proj/ticket/219> patch.
Thank you for your help!
Michael Speth
Research Systems Developer
Landcare Research
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130719/fc47d809/attachment-0001.html>
