[gdal-dev] ogr2ogr VSI support for JSON input?
Ryan Clark
ryan.clark at azgs.az.gov
Tue Jul 23 09:31:08 PDT 2013
I'm curious if the GeoJSON driver does not support the VSI API completely?
This works (stream WFS > GeoJSON):
curl "http://server.com/wfs?request=GetFeature..." | ogr2ogr -f "GeoJSON" /vsistdout/ /vsistdin/
but this doesn't (stream GeoJSON > KML):
cat ~/my-geojson.json | ogr2ogr -f "KML" /vsistdout/ /vsistdin/
... that is, I can't seem to stream GeoJSON as an input to ogr2ogr. Is that a known issue or am I doing something wrong? The documentation<http://www.gdal.org/ogr/drv_geojson.html> states that I should be able to do this, but I'm receiving an error:
$ cat my-geojson.json | ogr2ogr -f "KML" /vsistdout/ /vsistdin/
ERROR 1: GeoJSON parsing error: unexpected end of data (at offset 6000)
ERROR 4: Failed to read GeoJSON data
FAILURE:
Unable to open datasource `/vsistdin/' with the following drivers.
I'm working with GDAL 1.10.0.
Thank you!
Ryan
____________________
Ryan Clark
Arizona Geological Survey
ryan.clark at azgs.az.gov<mailto:ryan.clark at azgs.az.gov>
(520) 302-4871
facebook.com/ModernGeologist<https://www.facebook.com/ModernGeologist>
@worbly<https://twitter.com/worbly>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130723/ffa0cfb8/attachment.html>
