[gdal-dev] Call for discussion for "RFC 41 : Support for multiple geometry fields in OGR"
Even Rouault
even.rouault at mines-paris.org
Thu Jul 25 15:00:12 PDT 2013
I've added the following note in the RFC :
Note: before RFC41, SetGeometry() or SetGeometryDirectly() could work on a
feature whose feature definition had a GetGeomType() == wkbNone (which was
inconsistant). This will be no longer the case since the size of the
papoGeometries array is now based on GetGeomFieldCount(), and when
GetGeomType() == wkbNone, the geometry field count is 0. The VRT and CSV
drivers
will be fixed to declare their geometry type consistently.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
