[gdal-dev] Reading error with dwg and dxf files
Even Rouault even.rouault at mines-paris.org
Wed Jul 31 12:31:04 PDT 2013
Selon Xian Chen <chenxian at walkinfo.com.cn>:
Hi Xian,
If you want to debug that, you can have a look at the revelant code in
ogr/ogrsf_frmts/dxf/ogrdxf_hatch.cpp around line 250 and below, and in
ogr/ogrsf_frmts/dwg/ogrdwg_hatch.cpp around line 190 and below.
Best regards,
Even
> Hi all,
> I encountered an error when reading the attached dwg file using OGR. The
> last part is supposed to be a clockwise big circle arc, but is translated
> into a counterclockwise circle arc.
> I then converted the file into dxf and still have the error. Can anyone
> please help me out?
> Best regards,
> Xian
> Curvelines.dwg
> <http://osgeo-org.1560.x6.nabble.com/file/n5069826/Curvelines.dwg>
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Reading-error-with-dwg-and-dxf-files-tp5069826.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
