[gdal-dev] Clipping imprecision with gdal_translate
Eli Adam
eadam at co.lincoln.or.us
Tue Jun 4 17:14:51 PDT 2013
gdalwarp does have -tap which may be of some use. Quoting the doc page:
-tap:(GDAL >= 1.8.0) (target aligned pixels) align the coordinates of
the extent of the output file to the values of the -tr, such that the
aligned extent includes the minimum extent.
Best Regards, Eli
On Tue, Jun 4, 2013 at 12:35 AM, Ari Jolma <ari.jolma at gmail.com> wrote:
> JM,
> Looks to me that GDAL has clipped to the nearest pixel boundaries and not to
> the window you have provided. This is probably a feature. Maybe gdalwarp
> would do the kind of resampling you wish, but I'm not sure.
> Regards,
> Ari
> On 06/03/2013 03:37 PM, JM wrote:
> Hello List.
> At first i wanna thanks for the great work you are doing with the gdal
> library. It is a source of great tools and opportunities for spatial issues
> which whom i involed in.
> Among others i am using the commandline tool gdal_translate for clipping
> raster files via the following example command:
> gdal_translate -projwin 13.6666664938 53.2000002428
> 13.8333334784 53.1000017686 source.tif target.tif
> The source tif is already georeferenced (EPSG:4326). I would now assume that
> the boundingbox of the following GTiff is somethink like this:
> Lower Left: 13.6666664938 53.1000017686
> Upper Right: 13.8333334784 53.2000002428
> Instead it is something like this (the full gdalinfo dialog you can see in
> the attach to this mail):
> Lower Left: 13.6666610463 53.1000244672
> Upper Right: 13.8333191458 53.2000151873
> So there is a small imprecision in the clipping result. My question is now
> if this imprecision is normal (maybe a result of rounding operations within
> the clipping process) or if i do something wrong (do i miss something in my
> command).
> I am using libgdal1 version 1.9.0-3.1ubunut1. Looking forward to hearing
> from you.
> Kind regards,
> JM
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
