[gdal-dev] easy_install error
lazy
lazy at dark-matter.biz
Thu Jun 6 03:48:03 PDT 2013
I am having problems with easy_install-2.7 gdal
easy_install gdal
Searching for gdal
Reading http://pypi.python.org/simple/gdal/
Reading http://www.gdal.org
Best match: GDAL 1.9.1
Downloading
http://pypi.python.org/packages/source/G/GDAL/GDAL-1.9.1.tar.gz#md5=60cb0e0b652dfb204e150bcb11190248
Processing GDAL-1.9.1.tar.gz
Writing /tmp/easy_install-VbXRge/GDAL-1.9.1/setup.cfg
Running GDAL-1.9.1/setup.py -q bdist_egg --dist-dir
/tmp/easy_install-VbXRge/GDAL-1.9.1/egg-dist-tmp-_exdTD
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
extensions/gdal_wrap.cpp:2853:22: error: cpl_port.h: No such file or
directory
extensions/gdal_wrap.cpp:2854:24: error: cpl_string.h: No such file or
directory
extensions/gdal_wrap.cpp:2855:27: error: cpl_multiproc.h: No such file or
directory
extensions/gdal_wrap.cpp:2857:18: error: gdal.h: No such file or directory
extensions/gdal_wrap.cpp:2858:23: error: gdal_priv.h: No such file or
directory
extensions/gdal_wrap.cpp:2859:22: error: gdal_alg.h: No such file or
directory
extensions/gdal_wrap.cpp:2860:24: error: gdalwarper.h: No such file or
directory
extensions/gdal_wrap.cpp:4560:22: error: gdalgrid.h: No such file or
directory
extensions/gdal_wrap.cpp:2877: error: ‘CPLErrorHandler’ does not name a type
extensions/gdal_wrap.cpp:2880: error: expected initializer before
‘PythonBindingErrorHandler’
extensions/gdal_wrap.cpp:2753: warning: ‘swig_module’ defined but not used
error: Setup script exited with error: command 'gcc' failed with exit
status 1
Packages what are installed:
gdal-devel-1.9.2-4.el6.x86_64
gdal-java-1.9.2-4.el6.x86_64
gdal-1.9.2-4.el6.x86_64
gdal-libs-1.9.2-4.el6.x86_64
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130606/04d726ce/attachment.html>
