[gdal-dev] Two gdal-1.10.0 build errors
Jean-Claude Repetto
jrepetto at free.fr
Thu Jun 6 10:25:58 PDT 2013
On 06/06/2013 18:54, Andrew Brooks wrote:
> Hi
> Just a couple of problems:
> frmts/msg/msgcommand.cpp:434: error: 'sprintf' was not declared in
> this scope
> (needed a #include)
> --with-rename-internal-libtiff-symbols=yes and
> --with-rename-internal-libgeotiff-symbols=yes
> .libs/libgdal.so: undefined reference to `TIFFReadEncodedStrip'
> (had to configure without those options)
> Andrew
You should give some information about the OS and the compiler you use.
Jean-Claude
