[gdal-dev] SetFeature trouble! (HELP)
Mauro Pisano
mauropisano at suremptec.com.ar
Thu Jun 6 15:34:38 PDT 2013
Hi everyone!
I have a question about using the method OGRLayer::Layer().
Following i show you a protion of code:
// Create geometry from wkt
OGRGeometryFactory::createFromWkt(&pwkt, pSpatialRef, &pgeometry);
/** Configure geom
pCurrentFeature_->SetGeometry(&pgeometry);
if (pCurrentLayer_->SetFeature(pCurrentFeature_) != OGRERR_NONE) {
SHOW_ERROR(message_LAYER_MODIFIED_CLOSE_ERROR);
1: The SetFeature, returns with an error, but if I open the .DBF file I
found that the insert was made.
Then... why I have the Feature set?, taking account that the method is
returning FAIL.
2: Suppose that i have two features, and I open it and started to edit a
third feature. Whats
wrong in this case, is that after the insert, the value of the FID is a
very very very big number. Example:
Feature 1 = FID = 0;
Feature 2 = FID = 1;
Feature 3 = FID = 2893772.
I dont have any clue about whats happening, any kind of data will be
appreciated.
Thanks in advance,
Mauro Pisano
SUR Emprendimientos Tecnológicos
Perú 345 Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130606/3feb0bab/attachment.html>
