[gdal-dev] gml driver : access to the db temporary
Ari Jolma ari.jolma at gmail.com
Fri Jun 7 01:28:14 PDT 2013
On 06/06/2013 09:24 PM, Andrea Peri wrote:
> Hi,
> As reported in the GML driver page:
> when using the  GML_SKIP_RESOLVE_ELEMS HUGE method to resolve the GML.
> It will produce firstly a file-system based DBMS.
> I don't see this dbms file so probably itis removed fter it use.
> I'm interest to see its information. So there is a workaround to avoid
> this remove ?
If that is the case, then possibly you can avoid it by using a
programmatic interface to GDAL.
Ari
> thx,
> Andrea Peri
> qwerty àèìòù
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130607/75684523/attachment.html>
