[gdal-dev] Bad result when writing into KML without -t_srs
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Jun 7 02:35:44 PDT 2013
Even Rouault <even.rouault <at> mines-paris.org> writes:
> Logical behaviour when considering how -s_srs works. Basically -s_srs is
ignored
> completely if you don't also specify -t_srs. Probably a warning should be
issued
> to warn the user, and this should be documented in the manual page.
True, but there was also a logical reason for the mistake.  I was reading
from the manual page "Note that KML by specification uses only a single
projection, EPSG:4326" and therefore I just felt that specifying -t_srs is
unnecessary also in this context.
-Jukka Rahkonen-
