[gdal-dev] How robust is OGRSpatialReference::GetAuthorityCode?
Even Rouault
even.rouault at mines-paris.org
Sat Jun 8 13:53:58 PDT 2013
Le vendredi 07 juin 2013 06:50:26, David Strip a écrit :
> How well does OGRSpatialReference::GetAuthorityCode perform in the wild
> when handed a WKT? In particular, if I have satellite imagery from
> someplace in the world that was ortho-rectified in a "sane" manner to a
> national or state projection with an conforming WKT, will this function
> return an EPSG value? (I realize "robust" is somewhat ill-defined, but
> this is the best I could come up with in terms of my question. Sorry).
David,
OGRSpatialReference::GetAuthorityCode() should be pretty robust, in the sense
that it will return the authority code if an AUTHORITY[] node exists in the
WKT. Otherwise it will return NULL.
The key is to have a WKT with AUTHORITY in it, which is for example NOT the
case with the .prj files accompagning shapefiles.
You can also have a look at OGRSpatialReference::AutoIdentifyEPSG(), but don't
expect too much of it... See its doc.
Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
