[gdal-dev] NITF Chip
Baker, Anthony W
Anthony.W.Baker at boeing.com
Mon Jun 10 09:13:47 PDT 2013
I have a NITF file which I can read fine with GDAL. The issue that it is a chip and using the transformation to determine geolocations fails (for example finding the chip's four corners). Instead of placing a point based on the chip, it places it based on the whole image. I can read the metadata and see that the RPC metadata contains the chip offset:
RPC Metadata:
LINE_OFF=3276
LINE_SCALE=3276
SAMP_OFF=2538
SAMP_SCALE=2538
LONG_OFF=-106.8927
LONG_SCALE=0.0542
LAT_OFF=32.3084
LAT_SCALE=0.0593
HEIGHT_OFF=1229
HEIGHT_SCALE=1214
I am tempted to use the LINE_OFF and SAMP_OFF to make the adjustments to properly get the boundary. I believe this is only a partial solution (not generic enough) and will just give further problems as I get other NITF chips. Would someone help me with the proper way of handling the chip transformation?
Thank you,
Anthony
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130610/8d777cd6/attachment-0001.html>
