[gdal-dev] bugs: 2 examples of incorrect behaviour by gdal_rasterize with zero-polygon valid query result.
Even Rouault even.rouault at mines-paris.org
Wed Jun 12 11:23:23 PDT 2013
Le mercredi 12 juin 2013 19:58:20, Graeme B. Bell a écrit :
> Also:
> (using -init 255 will produce a TIFF with suitable nodata values in the
> second scenario I described, as a workaround.
> However, gdal_rasterize still does not produce correct command line output
> in this situation, and also it should not be necessary for users to
> manually add a -init option and manually synchronise the value with the
> -a_nodata value to ensure valid output from gdal_rasterize)
The fact that the first example inits the output TIFF to the nodata value is
specific to the working of the GeoTIFF driver, that returns non-instanciated
blocks initialized to the nodata value. With other output drivers, you could
also get a raster initialized to 0 instead of the nodata value. If you really
want to initialize the raster with a particular value in a reliable way,
always use -init.
I've pushed a fix in the dev version so that the progress bar appears in the
second case (SQL with 0 resulting rows).
> On Jun 12, 2013, at 7:50 PM, Graeme Bell <grb at skogoglandskap.no> wrote:
> > Summary:
> > I noticed that gdal_rasterize invents data values instead of burning
> > nodata values, incorrectly, in what is probably a common situation - a
> > valid query returning geometry columns but zero polygon rows.
> > Command line output suggests that nothing is being done, yet a GeoTIFF
> > with data values is silently rendered in the background.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
