[gdal-dev] about OGRSQL case sensitive
Even Rouault even.rouault at mines-paris.org
Thu Jun 13 15:00:58 PDT 2013
Le jeudi 13 juin 2013 09:46:16, 梁天辰 a écrit :
> Hi all,
> According to page http://www.gdal.org/ogr/ogr_sql.html , I found that <, >,
> <= and >= operators are case sensitive.
Hum, it appears that this was true before the rewriting of the OGR SQL engine
for GDAL 1.8.0. The current implementation of <, >, <= and >= is also case
insensitive as you've noticed... Not sure if we must change the doc or the
implementation here...
If you use GDAL 1.10.0, and you've built is with SQLite support, you can use
the following (convoluted) SQL :
"SELECT * FROM " + layername + " WHERE NOT codede != 'capital'"
and
poDSws->ExecuteSQL(sql,NULL,"SQLite");
so that the SQLite engine is used.
Well, why the above works, and not directly "SELECT * FROM " + layername + "
WHERE codede = 'capital'" since '=' is case sensitive (by default) in SQLite.
If you try this, the SQLite <--> OGR bridge will be smart and will forward the
WHERE clause to the OGR SetAttributeFilter() method, that in turns will be
evaluated by OGR SQL (for drivers that are not RDBMS). But by using "NOT foo
!= 'bar'" this optimization isn't triggered and the expression is fully
evaluated by the SQLite engine...
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
