[gdal-dev] Using OGRLayer::GetNextFeature() to read Dgn file ?
taibc taibc_coltech at yahoo.com
Fri Jun 14 01:02:32 PDT 2013
Hi everyone,
I am trying read features in a dgn file and convert to shape file.
Everything is ok before I adding the last while loop. After adding this
while loop, I can't exit the program. Please see my below codes.
Do you know why ?
OGRRegisterAll();
OGRDataSource       *poDS,  *poSHPDS;
OGRLayer  *poLayer;
poLayer = poDS->GetLayer(0);
OGRFeature *poFeature;
while( (poFeature = poLayer->GetNextFeature()) != NULL )
    OGRGeometry *poGeometry;
    poGeometry = poFeature->GetGeometryRef();
    if( poGeometry != NULL && (wkbFlatten(poGeometry->getGeometryType()) ==
wkbPolygon) && (poFeature->GetFieldAsInteger ("Level") == 62)
                && (strstr(poFeature->GetStyleString (), "BRUSH") != NULL))
         poLayer->SetSpatialFilter(poGeometry);
         OGRFeature *poTempFeature;
         while((poTempFeature = poLayer->GetNextFeature()) != NULL)
             if ((poTempFeature->GetGeometryRef () != NULL) &&
(poTempFeature->GetGeometryRef()->getGeometryType() == wkbPolygon)
                        && (strstr(poTempFeature->GetStyleString (),
"BRUSH") != NULL)
                        && poTempFeature->GetGeometryRef
()->Within(poGeometry)
                  poLayer->SetSpatialFilter(poTempFeature->GetGeometryRef
                  OGRFeature *poSubFeature;
                  while ((poSubFeature = poLayer->GetNextFeature ()) !=
NULL)
                       // do something
                       // Can't exit the programe after adding this while
loop
Thanks and regards,
Tai
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-OGRLayer-GetNextFeature-to-read-Dgn-file-tp5060084.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
