[gdal-dev] Using OGRLayer::GetNextFeature() to read Dgn file ?
taibc
taibc_coltech at yahoo.com
Fri Jun 14 18:14:42 PDT 2013
The problem is: after the last while loop. I need to set SetSpatialFilter and
Feature again (The spatialfilter that used in the previous while loop), by
using below codes:
poLayer->SetSpatialFilter (poGeometry);
poLayer->SetNextByIndex (index2-1);
Kind regards,
Tai
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-OGRLayer-GetNextFeature-to-read-Dgn-file-tp5060084p5060290.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
