[gdal-dev] Offset shapefile to start from prime meridian
Hare, Trent
thare at usgs.gov
Sun Jun 16 11:02:30 PDT 2013
There is a great method to do this virtually using GDAL's VRT format.
Unfortunately it looks like this site has died but the wayback machine has
a snapshot of it. Definitely a good tutorial to keep around -- I use this
trick all the time.
http://web.archive.org/web/20110406210056/http://www1.eonfusion.com/manual/index.php/Manipulate_rasters_with_GDAL_VRT
good luck,
Trent
On Sun, Jun 16, 2013 at 9:17 AM, zetah <otrov at hush.ai> wrote:
> I have Natural Earth shapefile covering whole globe in -180:180 range. I
> want to offset this file, so that it starts from Greenwich prime meridian
> instead -180.
> How can I do this with gdal/ogr?
> Thanks in advance
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130616/c970b8f7/attachment.html>
