[gdal-dev] Fwd: Accessing to GRIB bands
Roger Veciana i Rovira
rveciana at gmail.com
Tue Jun 18 03:42:28 PDT 2013
Hi Paolo,
I think that you will need a script. At least in my case, every file has
the bands written in a different order, no using directly the band number
is not possible. The only way I have found is to read the file metadata
using a python script:
from osgeo import gdal
from osgeo.gdalconst import GA_ReadOnly
grib_file = "wrf-03.2013060200_32.grib"
variable = "UGRD"
level = "950-ISBL"
dataset = gdal.Open(grib_file, GA_ReadOnly )
for i in range(1,dataset.RasterCount + 1):
band = dataset.GetRasterBand(i)
metadata = band.GetMetadata()
level_band = metadata['GRIB_SHORT_NAME']
variable_band = metadata['GRIB_ELEMENT']
if level_band == level and variable_band == variable:
bandnum = i
print bandnum
Of course, you have to change the filename, variable and level, and you'll
get the band number that fits the conditions. Then, just open this band and
do whatever you need.
I hope that helps.
Roger
2013/6/18 Paolo Corti <pcorti at gmail.com>
> On Tue, Jun 18, 2013 at 12:46 AM, Even Rouault
> <even.rouault at mines-paris.org> wrote:
> > From gdal_translate man page:
> > -b band:
> > Select an input band band for output. Bands are numbered from
> 1.
> > Multiple -b switches may be used to select a set of input bands to write
> to
> > the output file, or
> > to reorder bands. Starting with GDAL 1.8.0, band can also be
> set to
> > 'mask,1' (or just 'mask') to mean the mask band of the first band of the
> input
> > dataset.
> Hey Even
> thanks for the reply.
> I am well aware of the -b option, the problem here is that each raster
> has not the same bands order.
> Therefore, as I had to make some work on just one single band
> representing the same variable in all of the datasets, I ended up to
> write a script, iterate the datasets, then iterate the bands, read the
> metadata, and when found the correct band ran the process on it.
> thanks a lot in any case
> cheers
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130618/7862e2da/attachment.html>
