[gdal-dev] gdal_calc.py - new optional feature / performance improvement
Graeme B. Bell
grb at skogoglandskap.no
Fri Jun 21 01:58:17 PDT 2013
This may be of use to anyone who regularly uses gdal_calc.py.
http://trac.osgeo.org/gdal/ticket/5130
- easy patch
- you can get a performance boost of up to 33% depending on how you use gdal_calc or the type of data you have
- you can handle nodata processing with more flexibility if you prefer
- there's no risk of regressions or new complications for existing users
Thoughts/comments welcomed.
My own use case involves taking different actions in the calculation function depending on which input rasters have data or nodata values at a given point. The performance boost is just a bonus :)
Graeme.
