[gdal-dev] pcs.csv values don't match spatialreference.org
David Strip
gdal at stripfamily.net
Thu Jun 27 07:13:30 PDT 2013
SInce posting this, I've learned that the pcs.csv is in degree.minutes,
while the wkt is in decimal degrees, so that explains the pcs.csv. This
still leaves the question as to why autoIdentifyEPSG won't return the value.
On 6/26/2013 11:44 PM, David Strip wrote:
> I'm working with some files in Maryland State Plane (US foot), and
> autoIdentifyEPSG is failing. I tracked it down to what I suspect is
> the problem -
> my files and spatialreference.org show the standard parallels as 38.3
> and 39.45, with a latitude of origin at 37.66666666
> the pcs.csv file shows values of 38.18 and 39.27, with a latitude of
> origin at 37.4 (I don't actually know how to match the csv columns to
> the parameters, but these are the closest matching values).
> Why does the pcs.csv differ from spatialreference.org, and what is the
> appropriate strategy for fixing this?
> Thanks
> (and apologies for a cross-posting to stackexchange, which I posted
> before I realized the difference between the two sources)
> David
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
