[gdal-dev] C# version of ogr2ogr function
Genhan Chen GChen at camsys.com
Thu Jun 27 17:40:07 PDT 2013
Hi Tamas,
I am using pre-compiled ogr_csharp.dll, downloaded from
http://vbkto.dyndns.org/sdk/ . I added "using OSGeo.OGR" in front of the
class. and did not see any error during build process.
However, I got the following error message if any Ogr method (e.g. "
Ogr.RegisterAll();") was added in the program.:
{"The type initializer for 'OSGeo.OGR.OgrPINVOKE' threw an exception."}
System.Exception {System.TypeInitializationException}
Do you know what caused this error?
Thanks a lot,
Genhan Chen
Cambridge Systematics, Inc.
555 12th Street, Suite 1600
Oakland CA 94607
tel  510 873 8700
fax  510 873 8701
e-mail gchen at camsys.com
www.camsys.com
To:     Genhan Chen <GChen at camsys.com>,
Cc:     gdal-dev at lists.osgeo.org
Date:   06/26/2013 11:28 PM
Subject:        Re: [gdal-dev] C# version of ogr2ogr function
Please refer to this thread for further information:
http://lists.osgeo.org/pipermail/gdal-dev/2009-March/020130.html
Best regards,
Tamas
2013/6/26 Genhan Chen <GChen at camsys.com>
Hello,
I need a function (similar to ogr2ogr) to convert Shapefile into GeoJson
format.
How can I implement this function using C#, in .NET framework?
Any help is really appreciated!
Genhan Chen
Oakland CA 94607
tel  510 873 8700
fax  510 873 8701
www.camsys.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130627/b6c4c225/attachment.html>
