[gdal-dev] Set Attribute for dgn file when convert from shapefile
Truong Pham Minh
truong_pham_minh at yahoo.com
Sat Jun 29 19:55:04 PDT 2013
Hi list,
I try convert shapefile to dgn file with following command:
"ogr2ogr.exe -skipfailures -f "DGN" ..\..\..\te
st\data\test1.dgn ..\..\..\test\data\gridshape.shp -dsco SEED=..\data\seed_2d.dg
n"
the dgn file output always have level=0 in attribute field.
How could i set level=2 in dgn output?
Tks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130630/9e45678c/attachment.html>
