[gdal-dev] Cannot find gdaltransform's C wrapper
Even Rouault even.rouault at mines-paris.org
Fri Mar 1 19:57:07 PST 2013
Le vendredi 01 mars 2013 21:11:34, Ronak Bhatia a écrit :
> Hi,
> I'm using Yorick, a programming language similar to C and Matlab, and
> trying to port the function gdaltransform to Yorick. In order for me to do
> that, I have to find the C wrapper for the particular function and then I
> can work on porting it. I looked through gdal.h under gcore and no luck.
> Could you direct me to the right path?
The source code of the gdaltransform application is in apps/gdaltransform.cpp
> Thanks,
> R
