[gdal-dev] EDIGEO format
Yves Jacolin (Free)
yjacolin at free.fr
Wed Mar 6 06:20:20 PST 2013
Le jeudi 28 février 2013 18:51:17 Jürgen E. Fischer a écrit :
> Hi Yves,
> On Thu, 28. Feb 2013 at 16:16:02 +0100, Yves Jacolin (Free) wrote:
> > I am working on EDIGEO files, is this something I have to expect:
> Not sure what you question is.
> > $ ogrinfo *.THF
> > Had to open data source read-only.
> > INFO: Open of `E0000101.THF'
> > using driver `EDIGEO' successful.
> > FAILURE: Couldn't fetch requested layer E0000201.THF!
> This probably expands to
> ogrinfo E0000101.THF E0000201.THF
> i.e. list the layer "E0000201.THF" in the data source E0000101.THF - which
> is probably not what you meant.
Jürgen,
Thanks you were right, I forget to add "PARCELLE_id" (the layer name I need in
EDIGEO files).
I tests correctly for one file (ogrinfo E0000101.THF PARCELLE_id) but when I
went to test all my THF files I changed my command line.
Y.
