[gdal-dev] ogr2ogr with append fails to convert truncated fields
Tamas Szekeres
szekerest at gmail.com
Fri Mar 8 00:52:13 PST 2013
Added a ticket with the proposed implementation patch. Let me know how you
like it.
http://trac.osgeo.org/gdal/ticket/5021
Best regards,
Tamas
2013/3/2 Even Rouault <even.rouault at mines-paris.org>
> Le vendredi 01 mars 2013 20:57:43, Tamas Szekeres a écrit :
> > 2013/3/1 Even Rouault <even.rouault at mines-paris.org>
> > > There's even a 4th option that doesn't require any code change. Create
> a
> > > OGR
> > > VRT file that renames the source fields to the truncated shapefile
> field
> > > names (or
> > > the reverse : creates a OGR VRT that renames the truncated shapefile
> > > field names
> > > to the original field names, since OGR VRT now supports since a few
> > > versions
> > > CreateFeature())
> > This may probably work, but doesn't seem to be very user friendly.
> Actually
> > I would prefer to include at least a flag to indicate that ogr2ogr should
> > provide mapping the fields in the same order (don't lookup field index by
> > name) for example:
> > ogr2ogr -append -f "ESRI Shapefile" -nofieldreorder destination.shp
> > [source]
> > or with the previous fieldmap approach
> > ogr2ogr -append -f "ESRI Shapefile" -fieldmap "default" destination.shp
> > [source]
> I'm fine with -fieldmap. It will be just another advanced option (I'm
> culprit
> for a bunch of other options...). Perhaps "same_order" (or "identity" to
> be
> mathematically purist) instead of "default", since it's not actually the
> default behaviour (the default behaviour is to match the field names to
> build
> the field map). Some care should be done to check that the specified map
> is of
> the right size (number of fields of the source layer), or if
> "same_order"/"identity" is specified that the number of fields in the
> source and
> target layers are identical.
> As ogr2ogr can accept several source layers, perhaps a word of caution in
> the
> doc of the option to mention that the specified map applies to all source
> layers, so if they don't have the same field definition, the option might
> not be
> relevant in that case.
> > Best regards,
> > Tamas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130308/43ea5c13/attachment.html>
