Murat Beyhan <muratbeyhan28 <at> gmail.com> writes: > > Hi friends,I have a polygon shape file which is including district of the cityIt is latitude longitude data. And I try to transform it into UTM data Is it possible to do using gdal. Read http://www.gdal.org/ogr2ogr.html and you will make it. -Jukka Rahkonen-
