[gdal-dev] Difficulties reading a ODIM HDF5 file
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 13 08:45:42 PDT 2013
Sjur / Rutger,
It also seems to work fine for me with trunk on linux. I suspect the
problem is some sort of mixup at build time between versions of the
HDF include files or something like that. Very hard to debug such a
thing remotely.
Best regards,
Frank
On Wed, Mar 13, 2013 at 12:51 AM, Rutger <kassies at gmail.com> wrote:
> Hey,
> For what its worth; it works fine on Windows for me, using verion:
> GDAL 1.9.2, released 2012/10/08
> Gdalinfo output looks equal to your Linux output, and gdal_translate is able
> to convert the layer to a GeoTiff for example.
> Im using the pre-build cmd utilities from http://www.gisinternals.com/sdk/
> <http://www.gisinternals.com/sdk/> . Maybe you can peak over there to see
> if there is any difference in building.
> Regards,
> Rutger
> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-Difficulties-reading-a-ODIM-HDF5-file-tp5039864p5040058.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
