[gdal-dev] KAKADU jpeg 2000 driver
Livneh Yehiyam yehil at rafael.co.il
Wed Mar 13 12:39:28 PDT 2013
Frank
Thanks for the quick reply. I think I will be able to make the changes, test and post a patch.
Yehiyam
________________________________________
From: fwarmerdam at gmail.com [fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
Sent: Wednesday, March 13, 2013 17:23
To: Livneh Yehiyam
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] KAKADU jpeg 2000 driver
On Wed, Mar 13, 2013 at 4:55 AM, Livneh Yehiyam <yehil at rafael.co.il<mailto:yehil at rafael.co.il><table align='center'><tr><td></td></tr></table>> wrote:
Hi
Is it possible with the GDAL kakadu driver to specify the options of :
1.       Cuse_sop : to add SOP (start of packet) marker
2.       ORGtparts=R
Yehiyam,
Skimming the code in gdal/frmts/jp2kak/jp2kakdataset.cpp,
these do not seem to be supported parameters.  It looks like
it should be pretty easy to add them though.  If you look for
the two places that Qguard appears in that file it should be
fairly obvious how to add them.
Do you feel up to patching this yourself, and submitting
the change after testing?  If not, I could prepare the patch
if you are willing to test it.  Opening a ticket would be a good
first step.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com<mailto:warmerdam at pobox.com>
and watch the world go round - Rush    | Geospatial Software Developer
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not the intended recipient, you should contact us immediately and thereafter delete this message from your system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error, please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all electronic or other copies of the original message and any attachments thereof.
