[gdal-dev] Finding if a source exists in particular block of a VRTRasterBand
ryagz
raghavendra at vizexperts.com
Wed Mar 13 21:18:17 PDT 2013
I have created a VRTDataset and added multiple simple sources to its
rasterbands in a function of my application. In another function i have the
instance of this VRTDataset and its VRTRasterbands and, Now i would like to
find for a particular offsets an dimensions if there exists a source in
VRTRasterband.
I did not find any API functions to do this operations, so thought to call
functions from the classes and tried the code like bellow:
GDALRasterBand* preBand = dataSource->GetRasterBand(1);
VRTSourcedRasterBand* Vrtband =
dynamic_cast<VRTSourcedRasterBand*>(preBand);
int hasValidSource = 0;
for(int srcIndex = 0; srcIndex < Vrtband->nSources; srcIndex++)
VRTSimpleSource* simpleSource =
static_cast<VRTSimpleSource*>(Vrtband->papoSources[srcIndex]);
hasValidSource = simpleSource->GetSrcDstWindow(xoff, yoff, read_size[0],
read_size[1], read_size[0], read_size[1], &nReqXOff, &nReqYOff,
&nReqXSize, &nReqYSize, &nOutXOff, &nOutYOff, &nOutXSize, &nOutYSize );
To do this operation, the problem i am facing is VRTSimpleSource class is
not exported and so the function GetSrcDstWindow() is throwing a linker
errors.
Is there any way to solve this issue?
Or Is there any API function which does this operation?
Thanks,
Ryagz
View this message in context: http://osgeo-org.1560.n6.nabble.com/Finding-if-a-source-exists-in-particular-block-of-a-VRTRasterBand-tp5040251.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
