[gdal-dev] Polygonizer / Lines
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Mar 15 06:06:01 PDT 2013
Alisson,
Can you provide a sample dataset that didn't work?
On Fri, Mar 15, 2013 at 6:20 PM, Alisson Barbosa <alisson.uece at gmail.com>wrote:
> Thank you Chaitanya,
> I had read the explanation of Peter Halls. But that was *raster
> polygonization*. I am currently working with another type: *polygonization
> of OGRLineStrings*.
> My question was because i was not able to polygonize using the mentioned
> method. I created an OGRMultiLineString or an OGRGeometryCollection and
> added geometries (many OGRLineStrings) by addGeometry or
> addGeometryDirectly methods. But the polygonization always returned null.
> I solved using this:
> OGRMultiLineString *mls = new OGRMultiLineString();
> OGRMultiLineString* pTemp = NULL;
> while(...) //iteration of lines
>         //creation of line
>         pTemp = static_cast<OGRMultiLineString*>(mls->Union(line));
>         if (pTemp != NULL)
>             if( mls != NULL)
>                 if( mls->getNumGeometries() > 0)
>                     delete mls;
>             mls = pTemp;
> Thanks,
> 2013/3/14 Chaitanya kumar CH <chaitanya.ch at gmail.com>
>> Alisson,
>> You can refer to the method's documentation here:
>> http://www.gdal.org/ogr/classOGRGeometry.html#a674319670e735bf6d4049300096157ec
>> The mechanism of this operation was already explained Peter Halls in this
>> mailing list[1]. GEOS does a good job identifying line strings touching at
>> end points and then combining them to make rings and then polygons.
>> However, it's your job to ensure that all the line strings passed to the
>> method are part of a single polygon.
>> [1]: http://lists.osgeo.org/pipermail/gdal-dev/2012-November/034793.html
>> On Thu, Mar 14, 2013 at 11:58 PM, Alisson Barbosa <alisson.uece at gmail.com
>> > wrote:
>>> Can you explain a bit better?
>>>> Allison,
>>>> Check out OGRGeometry::Polygonize()
>>>> The result depends on the type of intersections in your lines.
>>>> Best regards,
>>>> Chaitanya Kumar CH
>>>> On 14 Mar 2013 21:53, "Alisson Barbosa" <alisson.uece at gmail.com> wrote:
>>>>> Hi friends,
>>>>> I have a set of OGRLineStrings and an OGRLinearRing with many
>>>>> intersections. I would like to polygonize this set of lines. Can anybody
>>>>> help me?
>>>>> Best regards,
>>>>> Alisson Barbosa
>>>>> Systems Analyst - FUNCEME
>>>>> M.Sc. in Computer Science - MACC
>>>>> Graduate in Computer Science  - UECE
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Alisson Barbosa
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
> Alisson Barbosa
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130315/ee4b3fbd/attachment-0001.html>
