[gdal-dev] Error compiling GDAL from trunk on Mac OS X 10.6.8
Jorge Arévalo
jorgearevalo at libregis.org
Fri Mar 15 14:53:36 PDT 2013
El viernes 15 de marzo de 2013 a las 22:36, Even Rouault escribió:
> Le vendredi 15 mars 2013 20:09:57, Jorge Arévalo a écrit :
> > Hello,
> > I'm getting an error compiling GDAL from trunk (r25758). I successfully
> > compiled GDAL from trunk before with this configure script:
> > https://dl.dropbox.com/u/6599273/gdal/configure_gdal.sh
> > But after last svn update to r25758, I get this error
> > https://dl.dropbox.com/u/6599273/errors/gdal_trunk_compile_error.log
> > I haven't compiled GDAL on Mac for a while. So, The problem isn't
> > necessarily caused by the last update.
> > Anyone else with the same problem?
> Cool that someone tests on the Mac and reports.
> Well, I assumed that "extern char** environ" that contains the environment
> variable was available on all POSIX platforms, but apparently not.
> http://www.gnu.org/software/gnulib/manual/html_node/environ.html suggests me
> the following patch. Please test and report if it works.
> Index: port/cpl_spawn.cpp
> --- port/cpl_spawn.cpp (revision 25734)
> +++ port/cpl_spawn.cpp (working copy)
> @@ -461,8 +461,13 @@
> #include <signal.h>
> #ifdef HAVE_POSIX_SPAWNP
> #include <spawn.h>
> +#ifdef MACOSX_FRAMEWORK
> +#include <crt_externs.h>
> +#define environ (*_NSGetEnviron())
> +#else
> extern char** environ;
> #endif
> +#endif
> #if 0
> > Thanks in advance,
Thanks! We got to the same solution :-). I've found the same patch in MacPorts (http://trac.macports.org/browser/trunk/dports/lang/hugs98/files/patch-packages-base-include-HsBase.h.diff?rev=81676). It worked.
I could create a new ticket and attach the patch file. Is it ok?
Jorge Arevalo
Freelance developer
http://www.krop.com/jorgearevalo
http://about.me/jorgeas80
Enviado con Sparrow (http://www.sparrowmailapp.com/?sig)
