[gdal-dev] ogr2ogr and PostGIS 2.0
Even Rouault
even.rouault at mines-paris.org
Thu Mar 21 02:54:07 PDT 2013
Selon EdH <ed.hudspeth at nnpa.org.uk>:
> Thanks for this suggestion, but I'm still getting the same error when I try
> another table in the same db called "lnr" (i.e. no hyphens).
You didn't specify which GDAL/OGR version you are using. You need GDAL/OGR 1.9
or later for PostGIS 2.0 compatibility.
http://osgeo-org.1560.n6.nabble.com/ogr2ogr-and-PostGIS-2-0-tp5041735p5042009.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
