[gdal-dev] WFS and HTTP compression
Jeremy Palmer
JPalmer at linz.govt.nz
Fri Mar 22 14:12:51 PDT 2013
Hi All,
I've being doing some bandwidth analysis when using GDAL/OGR trunk with a Geoserver WFS 1.1.0 server. I've found that gzip HTTP compression is not used when requesting the data in the GML2 and GML3 output format if OGR_WFS_USE_STREAMING is set to YES. However when requesting the GeoJSON output format (regardless of the OGR_WFS_USE_STREAMING setting) it is using HTTP gzip compression.
Is there a reason why HTTP compression is not used for GML when streaming is enabled?
Thanks,
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
