[gdal-dev] WFS and HTTP compression
Jeremy Palmer
JPalmer at linz.govt.nz
Fri Mar 22 14:54:13 PDT 2013
> Because it doesn't take the same code path (GML uses /vsicurl_steaming/ while
> other output formats use CPLHttpFetch() that downloads the whole file into
> memory and then parses it). I've just added GZip compression request in
> /vsicurl_streaming/ (can be turned off by setting CPL_CURL_GZIP to NO)
Thanks Even!
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
