[gdal-dev] import error on fedora?
Chao YUE
chaoyuejoy at gmail.com
Tue Mar 26 10:18:16 PDT 2013
Dear all,
I use "yum install gdal" to install gdal on fedora 16,
I can see all following commands in the terminal:
ychao at lsce3139:~$ gdal
gdaladdo gdal_contour gdalenhance gdalinfo
gdal_rasterize gdaltransform gdalwarp
gdalbuildvrt gdaldem gdal_grid gdalmanage
gdaltindex gdal_translate
However when I tried to import gdal, I get import error:
In [1]: import gdal
ImportError Traceback (most recent call last)
<ipython-input-1-27bf4694dd2b> in <module>()
----> 1 import gdal
ImportError: No module named gdal
In [2]: from osgeo import gdal
<ipython-input-2-a04b80bf4e65> in <module>()
----> 1 from osgeo import gdal
ImportError: No module named osgeo
so what's going on here? thanks for any response.
best regards,
chao
Chao YUE
Laboratoire des Sciences du Climat et de l'Environnement (LSCE-IPSL)
UMR 1572 CEA-CNRS-UVSQ
Batiment 712 - Pe 119
91191 GIF Sur YVETTE Cedex
Tel: (33) 01 69 08 29 02; Fax:01.69.08.77.16
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130326/f450cde9/attachment.html>
