[gdal-dev] Gdal_translate terminated - buffer overflow detected
Ondrej Chlup
chlup.ondra at gmail.com
Thu Mar 28 15:25:33 PDT 2013
GDAL 1.10 works without errors. Thanks.
Ondrej
2013/3/28 Even Rouault <even.rouault at mines-paris.org>
> Selon Ondrej Chlup <chlup.ondra at gmail.com>:
> > Hi,
> > I was using GDAL version 1.9.1 to get NTv2 grid from raster in PostGIS
> > using gdal_translate. I got the error: 0*** buffer overflow detected ***:
> > gdal_translate terminated
> > I was trying to use GDAL version 1.9.2 but with the same error. Is there
> > any way how to fix it?
> You are probably running into a knwown problem of the PostgisRaster driver
> http://trac.osgeo.org/gdal/ticket/4703 that has been fixed in the dev
> version
> (GDAL 1.10dev)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130328/296ad20b/attachment.html>
