[gdal-dev] GoogleEarth wont read KML files created by ogr2ogr: Unknown element <Schema>
Hermann Peifer
peifer at gmx.eu
Wed May 1 17:07:46 PDT 2013
FYI, some 4 years ago, I reported an XML schema validation error related
to the <Schema> element: http://trac.osgeo.org/gdal/ticket/2858. IIRC,
the explanation at the time was that there are some limitations with the
kml driver and "the real solution is to switch to libkml..."
Hermann
On 2013-05-01 19:40, Frank Warmerdam wrote:
> Nikos,
> Could you file a ticket, and attach a working and nonworking kml example?
> Any idea if this behavior varies across versions of google earth? I
> wonder if libkml can read the file(s) ok.
> Best regards,
> Frank
> On Wed, May 1, 2013 at 3:30 PM, Nikos Alexandris
> <nik at nikosalexandris.net <mailto:nik at nikosalexandris.net>> wrote:
> Hi!
> I work with GDAL 1.9.2, compiled from source with support for expat
> and KML
> under Kubuntu 12.10. Any attempt to convert a(ny) shapefile (be it
> of type
> point or polygon) using ogr2ogr (or exporting from GRASS GIS or/and
> QGIS --
> all based on the same GDAL librairies) results in a .kml file that
> Google-
> Earth (version 7. ) wont read with the "excuse": Unknown element
> <Schema>.
> Even the example KML file over at
> <https://developers.google.com/kml/articles/vector> is rejected by
> GE with the
> same error message.
> Removing the <Schema> entries altogether, makes the file readable by GE.
> Anyhow, GE reads without problems a KML example (that includes Schema
> elements) to be found over at
> <https://developers.google.com/kml/documentation/extendeddata> (look
> for the
> Example under "Adding Typed Data to a Feature").
> What are the odds?
> Thank you, Nikos
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com <mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
