[gdal-dev] Polygon simplification using the borders to preserve topology
Roger Veciana i Rovira
rveciana at gmail.com
Thu May 2 03:22:48 PDT 2013
Hello,
I have the a shapefile full of polygons, and* *I want to simplify them,
preserving the points they share.
ogr2ogr -simplify simplifies each polygon independently, so the borders
don't fit properly.
Is there a way to do this with GDAL? TopoJSON format(
https://github.com/mbostock/topojson), for instance, uses the shared
segments instead of the polygons, and simplifies them well, but I prefer to
use GDAL.
Thank you
Roger
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130502/15aafb33/attachment-0001.html>
