[gdal-dev] [SPAM?]: Re: Adding labels / specifying styles
Newcomb, Doug
doug_newcomb at fws.gov
Thu May 2 09:56:45 PDT 2013
Benoit,
The Atlas plugin for qgis 1.8.0 , http://plugins.qgis.org/plugins/atlas/ ,
might do what you want. It's in the offiicial repository.
Doug
On Thu, May 2, 2013 at 12:06 PM, Tyler Mitchell
<tyler.mitchell at actian.com>wrote:
> > However, I deal with a great number of files and I would like to
> accelerate the process. That is why I am asking for a script based
> solution. I can already import all my shapefiles with a Python script. I
> would like to indicate which column to use as label.
> I see... perhaps you could look at creating QGIS project files directly.
> Once you know the pattern you should be able to automate what you need, as
> the file is just XML and you can create one manually and inspect it. I
> look forward to hearing what you figure out.
> Tyler
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior. Life is too short for undocumented, proprietary data formats.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130502/0a359f92/attachment-0001.html>
